Git support for Zeus?
cclayson
Post by cclayson »
Jussi et al.,
I know that Zeus supports SVN, but, is there support for Git?
Cameron
P.S. Your editor is by far the best that I have encountered. I have used it for years and am very pleased.
Re: Git support for Zeus?
Hi Cameron,
For version control Zeus implements the MS-SCCI interface and that means any version control with that interface should work with Zeus.
A quick Google search of MS-SCCI and Git came up with quite a few hits: https://www.google.com.au/search?q=MS-S ... 0gSetL_wDQ
So based on those search results I would say this might indeed be possible :?:
But personally, I'm old fashion as I still get by using Zeus with Subversion ;)
Thanks. I glad you like it :)
There is now an Agent Git plug-in that adds MSSCCI support for Git.
As Zeus also supports MSSCCI it means Zeus now does have an option for Git support.
You can read more about Agent Git from here: http://www.zeusedit.com/agentgit/index.html
