Set INI file
E Programmer
Set INI file
Post by E Programmer »
I'm installing your latest. In the past I have used
zeus.exe -izeus.ini
to use a different ini for each directory. This does not seem to be making any difference this time. I get the same result for
c:\progra~1\zeus\zeus.exe
and
c:\progra~1\zeus\zeus.exe -izeus.ini
I've also tried
c:\progra~1\zeus\zeus.exe -i zeus.ini
Do I have to do something special to force zeus to look in the local directory?
The code that does the parsing of the command line options was recently changed and what you have found is a bug in this new code :(
To make it work change the command line to be this instead:
The parsing code will also be fixed to support the old command line format ;)
E Programmer
So sad :( ... still not working.
This is what I did
1) to make sure there is no local ini file:
del zeus.ini
2) run zeus as suggested
3) I then opened a file and closed zeus, checked for the ini
dir zeus.ini
result
File Not Found
4) I switched to another directory and opened zeus
It opened the file automatically that I had opened above. Not used a local zeus.ini, but a global zeus.ini
E Programmer
I have a workaround
zeus.bat:
  • rem move to the drive/directory where I am working
    call drive.bat
    if exist zeus.ini goto CopyIt
    goto None
    :CopyIt
    rem Copy local zeus.ini and replace the one Zeus will use
    copy /Y zeus.ini c:\users\eet\AppData\Roaming\Xidicone\Zeus
    :none
    rem Do my editing
    rem Copy the ini file used by Zeus to my local directory
    copy c:\users\eet\AppData\Roaming\Xidicone\Zeus\zeus.ini zeus.ini
Let me know if you get the -i option working. :)
I have uploaded a new beta version and hopefully this bug is now fixed:
http://www.zeusedit.com/zforum/viewforum.php?f=6
As a test I ran these two command lines and both created the required test.ini file:
zeus -s -i c:\temp\test.ini
zeus -s -ic:\temp\test.ini
E Programmer
I got the beta version working.
I found that zeus -i test.ini did not work, BUT zeus -i .\test.ini DID work. Yeah!
This issue is now be fixed in the lastest version found here: http://www.zeusedit.com/zforum/viewforum.php?f=6
