File sort
yves
File sort
Post by yves »
When I would like to open a file, since I have installed XP SP3, i don't have files sorted by name and each time, I must right click and select sort by name .
You need to use the Options, Editor Options menu and in the General section turn on the Automatically sort files on open option ;)
If you don't see this option then you need to get the latest version of Zeus from here: http://www.zeusedit.com/download.html
This should fix the issue, but if it doesn't please let me know.
yves
Post by yves »
I have installed the latest version 3.96r , checked the automatically sort file on open, restarted my zeus editor and I have the same problem again.
How do you open the files :?:
For me, when this option is set, any file opened with the File, Open menu is displayed in it's correctly sorted position in the file tab bar :?
The files are also sorted correctly when they are opened via the navigator.
So for me the sorted feature is working just fine. Do we have the same picture of how this sorted feature is meant to work :?:
