Zeus + Go Build
Zeus + Go Build
The latest release of the Zeus IDE adds support for Go Build.
Go Build (gb) is an alternative build tool for the Go programming language.
More details about gb can be found here: http://dave.cheney.net/2015/05/12/introducing-gb
How Go Build Works
To see how Go Build works consider the Converting and Existing Project found here: http://getgb.io/examples/getting-started/
Now assuming Git, Go and Go Build are all installed an in the PATH environment variable, the steps described in the link above can be replicated inside a Window command line prompt as shown below:
C:\projects]mkdir devel\sftp
C:\projects]cd devel/sftp
C:\projects\devel\sftp]mkdir src\github.com\pkg\sftp
C:\projects\devel\sftp]git clone https://github.com/pkg/sftp src/github.com/pkg/sftp
Cloning into 'src/github.com/pkg/sftp'...
remote: Counting objects: 468, done.
remote: Compressing objects: 100% (5/5), done.
remote: Total 468 (delta 0), reused 0 (delta 0), pack-reused 463
Receiving objects:  99% (464/468), 1.32 MiB | 238.00 KiB/s
Receiving objects: 100% (468/468), 1.39 MiB | 244.00 KiB/s, done.
Resolving deltas: 100% (257/257), done.
Checking connectivity... done.
C:\projects\devel\sftp]mkdir vendor\src\github.com\kr\fs
C:\projects\devel\sftp]git clone https://github.com/kr/fs vendor/src/github.com/kr/fs
Cloning into 'vendor/src/github.com/kr/fs'...
remote: Counting objects: 18, done.
remote: Total 18 (delta 0), reused 0 (delta 0), pack-reused 18
Unpacking objects: 100% (18/18), done.
C:\projects\devel\sftp]mkdir vendor\src\golang.org\x\crypto
C:\projects\devel\sftp]git clone https://github.com/golang/crypto vendor/src/golang.org/x/crypto
Cloning into 'vendor/src/golang.org/x/crypto'...
remote: Counting objects: 1889, done.
remote: Total 1889 (delta 0), reused 0 (delta 0), pack-reused 1889
Receiving objects: 100% (1889/1889), 1.20 MiB | 205.00 KiB/s, done.
Resolving deltas: 100% (1262/1262), done.
C:\projects\devel\sftp]gb build all
github.com/kr/fs
golang.org/x/crypto/ssh
golang.org/x/crypto/ssh/agent
github.com/pkg/sftp
github.com/pkg/sftp/examples/buffered-read-benchmark
github.com/pkg/sftp/examples/buffered-write-benchmark
github.com/pkg/sftp/examples/gsftp
github.com/pkg/sftp/examples/streaming-read-benchmark
github.com/pkg/sftp/examples/streaming-write-benchmark
How to Use Go Build Inside Zeus
The latest version of Zeus adds a Python macro that is designed to work with Go Build and it does this by automatically creating a Zeus workspace that matches the Go Build project.
1. To see how this works just open this file in Zeus:
C:\projects\devel\sftp\src\github.com\pkg\sftp\sftp.go
2. Next with that Go file as the active file, select the Macros, Build, New Go Workspace menu and run that macro to create an load the Go Build workspace.
3. The readme.txt file gives more details on how the macro works.
Running that macro will create a new workspace with a structure as shown below:
To run the go build, right click on the github.com and select the build all option as shown below:
This will result in the following output:
Using workspace project options....
github.com/kr/fs
github.com/pkg/sftp
Class Browsing and Code Navigation
One of the benefits of having a workspace is Zeus will automatically create ctags information for each of the items of the workspace.
Zeus displays that information in it's class browser tree as shown below.
Zeus also uses that ctags information to drive the code navigation.
