Rust Language Tutorial
Here are the steps required to use the Rust compiler inside of Zeus.
Step 1:
Download and run the installed the Rust installer from the following page: http://www.rust-lang.org/install.html
When you running the installed accept the default installation folder.
Also accept the installer offer to add that installation folder to the system PATH environment variable.
Step 2:
Start Zeus and use the Tools, DOS Command Line menu to run this command:
rustc.exe --version
Running that command should result in output something like this:
rustc 1.15.1 (021bd294c 2017-02-08)
If you do not see this output it means the previous installation step has not worked.
Step 3:
Inside Zeus and create a simple c:\temp\test.rs file:
fn main() {
    println!("Hello, world!");
Step 4:
Use the Compiler, Compile menu to compile and link that file.
Then use the Macros, Execute Test.exe menu to run the executable and you should see this result:
Hello, world!
Setting up the Language Server
To setup the Rust language server follow the instructions found here: https://www.zeusedit.com/lsp/rust.html
