Go Plus Script
Go Plus Script
This Zeus script automates the checking of Go code for correctness by running the go fmt, goimports, golint, go vet and go build commands each time the file is saved.
Refer to the script comments for details on how to use this script.
#        Name: Go Plus Script
#      Author: Jussi Jumppanen
#    Language: Python
# Description: This script will run gofmt, goimports, golint, go vet and
# go build on the current file and capture any error output produced.
# The script will run the following Go command on the current file
# in the order listed:
#     gofmt
#     goimports
#     golint
#     go vet
#     go build
# If any errors are detected they will be reported to the user with
# the line number, error message and file name allowing the user to
# quickly navigate to the error.
# This macro assumes the imports, vet and lint packages have been
# downloaded, built and correctly installed:
#     lint    - https://github.com/golang/lint
#     imports - http://godoc.org/code.google.com/p/go.tools/cmd/goimports
#     vet     - http://godoc.org/code.google.com/p/go.tools/cmd/vet
# To make this script run on file save just use the Options, Editor Options
# menu and in the Triggers panel set this as the File Save Portfix script:
#     $zud\zScript\go_plus.py
import os
import zeus
import os.path
def goplus_trigger():
    # get the document type for the current file
    document_type = zeus.macro_tag("$DTD")
    if (document_type != "Go Document Type"):
        # ignore this file as it is not a Go document type
        return 1
    # macro only works for documents
    document = zeus.is_document()
    # macro only works for read/write documents.
    locked = zeus.is_read_only()
    # macro only works for named documents.
    named = zeus.is_named()
    if (locked == 1) or (document == 0) or (named == 0):
      # can't run the format on current document
      zeus.message("This macro only works with named, writable Go documents.")
      zeus.beep()
      return 0
    # the details of the current document
    file_base = zeus.macro_tag("$f")
    file_name = zeus.macro_tag("$fn")
    # the output file name
    file_output = file_name + ".ztow"
    # the compiler error name
    file_error = file_name + ".zerr"
    # remove any previous output file
    if os.access(file_output, os.F_OK):
        os.remove(file_output)
    # remove any previous error file
    if os.access(file_error, os.F_OK):
        os.remove(file_error)
    result = 0
    if result == 0:
        # run gofmt
        result = go_fmt(file_name, file_output)
    if result == 0:
        # run goimports command
        result = go_imports(file_name, file_output)
    if result == 0:
        # run go lint command
        result = go_lint(file_name, file_output)
    if result == 0:
        # run go vet command
        result = go_vet(file_name, file_output)
    if result == 0:
        # run go build command
        result = go_build(file_name, file_output)
    if result == 0:
        zeus.message("File: '" + file_base + "' save completed.")
def go_build(file_name, file_output):
    # the go build command
    return run_cmd("go build", file_name, file_output)
def go_fmt(file_name, file_output):
    # -- usage: gofmt [flags] [path ...]
    # --   -cpuprofile="": write cpu profile to this file
    # --   -d=false: display diffs instead of rewriting files
    # --   -e=false: report all errors (not just the first 10 on different lines)
    # --   -l=false: list files whose formatting differs from gofmt's
    # --   -r="": rewrite rule (e.g., 'a[b:len(a)] -> a[b:]')
    # --   -s=false: simplify code
    # --   -w=false: write result to (source) file instead of stdout
    # the gofmt command
    return run_cmd("gofmt.exe -w=true -e=true", file_name, file_output)
def go_imports(file_name, file_output):
    # the goimports command
    return run_cmd("goimports.exe -w=true", file_name, file_output)
def go_lint(file_name, file_output):
    # the golint command
    return run_cmd("golint.exe", file_name, file_output)
def go_vet(file_name, file_output):
    return run_cmd("go vet", file_name, file_output)
def check_file_errors(file_errors):
    # see if any output was produced
    have_errors = 0
    if (os.path.isfile(file_errors)):
        statinfo = os.stat(file_errors)
        if statinfo.st_size > 0:
            have_errors = 1
    return have_errors
def check_lfn(file_name):
    # check if file contains any whitespace
    if (file_name.find(' ') <> -1):
        # add quotes to the output file name
        file_name = '"' + file_name  + '"'
    return file_name
def run_cmd(cmd, file_name, file_errors):
    # run the command as a DOS command in hidden window and wait for it to finish
    flags = 16+32
    # check all files for LFN details and pipe stdout, stderr to the errors file
    cmd = cmd + " " + check_lfn(file_name) + " > " + check_lfn(file_errors) + " 2>&1 "
    # run the command
    result = zeus.system(cmd, "", flags)
    # reload the file in case it was changed by the command
    zeus.FileReloadCurrent()
    have_errors = check_file_errors(file_errors)
    #zeus.message_box(0, cmd, result)
    # see if there where any errors runninf the command
    if (result != 0) or (have_errors != 0):
        # see if we have and error files
        if have_errors:
            # open the error file in compiler output window
            zeus.file_open_compiler(file_errors, cmd, file_name)
        else:
            # make sure the user will see the error
            if zeus.is_debug_enabled() == 0:
                zeus.debug_enable()
            # log the command to the debug window
            zeus.debug_output(cmd + "\n\n" + "Error executing the 'Go Plus' script!\n")
            # set capture flags
            flags = 1+32+2+4
            # run the format again but this time capture the error output
        # we have errors
        result = 1;
    # on success we return zero
    return result
goplus_trigger() # run the macro
kurasov1965K
Go Plus Script
Post by kurasov1965K »
Hello. Can you help me with a script.
In your programm is the script that delete all spaces in the end of lines. How can I do this with the startspaces?
Sorry for my English. Hope you understand me.
Re: Go Plus Script
Zeus does delete white space from the end of lines but that is not a script.
That is built in to the editor and controlled by an option in the General section of the Options, Editor, Options menu.
Once again there would be many ways to do this.
One option would be use a regular expression as shown in the Zeus Python script below:
#        Name: Trim White Space
#    Language: Python
# Description: This macro will remove white space from the start of all
#              the lines in the current file.
import zeus
def key_macro():
    if zeus.is_document():
        if zeus.is_read_only() == False:
            # the find regular expression
            find = '^[ \t ]+(.+)'
            # note: the '\' needs to be delimited as '\\'
            replace = '\\1'
            # do the replace all for the regular expressions provided
            zeus.replace_all(find, replace, True)
        else:
            zeus.message('This macro only works for writable documents.')
            zeus.beep()
    else:
        zeus.message('This macro only works for documents.')
        zeus.beep()
key_macro()  # run the macro
If you save the code above to the trim.py file and save it to the Zeus zScript folder, you will be able to run this script using the Options, Execute Script menu and entering in this command:
trim
Naturally you could also bind the macro to the menu and/or to the keyboard.
