Using TinyCOBOL with Zeus
These are the steps I performed to get installing and use the TinyCOBOL compiler from inside Zeus:
(1) Downloaded for the TinyCobol package found here.
(2) Run the installer into the default install folder: C:\MinGW
(3) Create the following Test.cob COBOL file:
      * Hello World Program
      IDENTIFICATION DIVISION.
      PROGRAM-ID.  "cobmain".
      DATA DIVISION.
      WORKING-STORAGE SECTION.
      01  MYVAR PIC X(20).
      PROCEDURE DIVISION.
      DisplayPrompt.
           MOVE "HELLO" to MYVAR
           DISPLAY "Hello, world.".
           STOP RUN.
(4) I use the Options, Document Types menu to edited the Zeus COBOL document type and defined the compiler command line as follows:
htcobol.exe -M "$fn"
and added the C:\MinGW\bin\ to the computers PATH environment variable.
(5) When I ran the Zeus compile on the Test.cob COBOL file I got the following error:
'as.exe' is not recognized as an internal or external command,
It turns out as the name suggest the COBOL compiler needs the MinGW GCC back end compiler.
(6) So I got the MinGW-5.1.4.exe package found here: http://sourceforge.net/project/showfile ... up_id=2435
This is an small installer program. When you run it, it does a remote install of the MinGW in the same folder as TinyCobol.
After running the above installer the missing as.exe file was now in the installation folder.
Edit: This link provides some alternate instructions on how to download and install the MinGW compiler backend:
http://www.zeusedit.com/zforum/viewtopic.php?t=6957
(7) TinyCobol also needs the Berkeley's DB library which I found here:
http://tiny-cobol.sf.net/dl/db-1.85-ac.mingw32.zip
I extracted the library and header files contained in the zip file into the library and header folders of the C:\MinGW\ folder.
To get things to work I also had to copy the libdb.a to libdb1.a
(8) TinyCobol also needs the New Curses Library.
I found the pdcurses-2.6.0-2003.07.21-1.exe installer here:
http://sourceforge.net/project/showfile ... e_id=24937
I ran the installer into the C:\MinGW\
Now when I repeated step 4 I found that a Test.exe file was in fact produced :)
But unfortunately when I ran the Test.exe it ran without error but it did not print the expected Hello world output :(
My conclusion is the TinyCobol will probably work but it does require a fair bit of tweaking. I not really sure why the resulting executable did not produce the output expected :?
Edit: I suspect the reason the Test.exe did not print the expected Hello world output was because of a DLL mixup on my system. A similar problem was noticed when setting Zeus up to run the GNU C++ compiler.
More details on the problem and the fix can be found here: http://www.zeusedit.com/zforum/viewtopic.php?t=6959
