Python debugger (something else required)
Colleagues
I tried to run python debugger for simple script and observed message that printed below. What additional file should be installed
I checked and find out that actually directory C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeu is alive
With Best Regards
Alexander
Zeus - Version 3.97p
Copyright (c) Xidicone P/L 1993-2013. All rights reserved.
Using implied script: C:\Users\alexander.gorlov\Documents\Projects\python-test-test\join-test-suite.pyModule:'C:\Users\alexander.gorlov\Documents\Projects\python-test-test\join-test-suite.py'
Directory:'C:\Users\alexander.gorlov\Documents\Projects\python-test-test\'
Command Line:'pythonc.exe -S -u C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeu C:/Users/alexander.gorlov/Documents/Projects/python-test-test/join-test-suite.py '
pythonc.exe: can't open file 'C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeu': [Errno 2] No such file or directory
With Best Regards
Alexander
I'm not quite sure what is going on
It looks like the command has been truncated
What the debugger command line should look like is this:
Could you try the latest Zeus beta found here: http://www.zeusedit.com/z300/ze397q-beta.zip
When you run the debugger in that version it should hopefully look something like this:
Command Line:'pythonc.exe -S -u "C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeus\zScript\PyLib\pdb.py" C:\Users\alexander.gorlov\Documents\Projects\python-test-test\join-test-suite.py 'When you run the debugger in that version it should hopefully look something like this:
Using implied script: C:\Users\alexander.gorlov\Documents\Projects\python-test-test\join-test-suite.py'
Directory:'c:\temp\'
> c:\temp\test.py(4)<module>()
-> import sys
(Pdb)I've update current installation of Zeus(3.97p) with recommended archivejussij wrote:I'm not quite sure what is going on
What the debugger command line should look like is this:Could you try the latest Zeus beta found here: http://www.zeusedit.com/z300/ze397q-beta.zipCode: Select all
When you run the debugger in that version it should hopefully look something like this:Cheers JussiCode: Select all
Using implied script: C:\Users\alexander.gorlov\Documents\Projects\python-test-test\join-test-suite.py' Directory:'c:\temp\' Command Line:'pythonc.exe -S -u "C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeus\zScript\PyLib\pdb.py" C:\Users\alexander.gorlov\Documents\Projects\python-test-test\join-test-suite.py ' > c:\temp\test.py(4)<module>() -> import sys (Pdb)
Debugger does not start, no messages, no error, no warning
This I found in error logjussij wrote:I'll have to take a closer look at Zeus code to try and figure out what might be going wrong.
That might take a day or two.
Zeus - Version 3.97q - Beta2
[Thu Jul 11 16:15:00 2013] TRACE ".\zfwsys01.cpp" (2121) >> Created Common Data folder: C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeus\zBackup
[Thu Jul 11 16:15:00 2013] TRACE ".\zfwsys01.cpp" (2121) >> Created Common Data folder: C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeus\zConfig
[Thu Jul 11 16:15:00 2013] TRACE ".\zfwsys01.cpp" (2121) >> Created Common Data folder: C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeus\zExample
[Thu Jul 11 16:15:00 2013] TRACE ".\zfwsys01.cpp" (2121) >> Created Common Data folder: C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeus\zHelp
[Thu Jul 11 16:15:00 2013] TRACE ".\zfwsys01.cpp" (2121) >> Created Common Data folder: C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeus\zScript
[Thu Jul 11 16:15:02 2013] TRACE ".\zfwsys01.cpp" (2121) >> Created Common Data folder: C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeus\zSpell
[Thu Jul 11 16:15:02 2013] TRACE ".\zfwsys01.cpp" (2121) >> Created Common Data folder: C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeus\zTags
[Thu Jul 11 16:43:45 2013] ASSERT ".\zfwdoc01.cpp" (1471) >>
[Thu Jul 11 17:12:51 2013] ASSERT ".\zfwdvw01.cpp" (3191) >>
[Thu Jul 11 17:34:32 2013] ASSERT ".\zfwdvw01.cpp" (3191) >>
Insure the executable is found in the system PATH environment variable.
i activated python debugger and observed the same situation with cut command
Using implied script: C:\Users\alexander.gorlov\Documents\Projects\wd\wd.pyModule:'C:\Users\alexander.gorlov\Documents\Projects\wd\wd.py'
Directory:'C:\Users\alexander.gorlov\Documents\Projects\wd\'
Command Line:'pythonc.exe -S -u C:\Users\alexander.gorlov\AppData\Roaming\Xidicone\Zeu C:/Users/alexander.gorlov/Documents/Projects/wd/wd.py '
Do you have any updates regarding this problem?
I have managed to replicate this issue on a Windows 7 machine.
It appears the command line is being truncated, as can be seen from the debug output
The Python debugger is found in the pdb.py file and that is the file that seems to be getting truncated.
So the plan is to try and have the python.exe find the pdb.py file, without it having to be fully qualified, which will reduce the size of the command line and hopefully stop the truncation.
That is the plan but it still needs to be coded and fully tested.
This issue should be fixed in the latest beta version found here: http://www.zeusedit.com/z300/ze397q-beta.zip
To test the debugger, make sure no workspace is open, open a Python test file and use the Debugger, Start menu to start the debugger.
