PHP Function DocBlock
The following Zeus Lua macro creates a PHP function DocBloc.
Consider a PHP function like this.
    function myCmp ($a, $b)
Running this macro will then create the following DocBlock:
     * @param type $a
     * @param type $b
     * @return type
Here is the macro source code:
--        Name: PHP Function DocBlock
--    Language: Lua Macro
-- Description: This macro creates a PHP function DocBlock. To use the macro
--              place the cursor on the line containing the function or the
--              line preceeding the function and just run the macro.
--    Example:  Consider a function like this.
--                  function myCmp ($a, $b)
--              Running this macro will then create the following DocBlock:
--                   * @param type $a
--                   * @param type $b
--                   * @return type
-- trim a string
function string:trim()
    return (self:gsub("^%s*(.-)%s*$", "%1"))
-- split a string on the delimiter
function string:split(delimiter)
    local result = { }
    local from = 1
    local delim_from, delim_to = string.find(self, delimiter, from)
    while delim_from do
        table.insert(result, string.sub(self, from, delim_from - 1))
        from = delim_to + 1
    table.insert( result, string.sub(self, from ))
    return result
    local locked = is_read_only()
        beep();
        return;
    local current = true
    local line    = get_line_pos()
    local text    = get_line_text(line)
    -- look for the function details on the current line
    local index1, index2, func, brace1, args, brace2 = string.find(text, "function ([%a]+)[%s]*(%(*)(.*)(%)+)"  )
    if func == nil then
        text = get_line_text(line + 1)
        -- look for the function details on the next line
        current = false
    if func ~= nil then
        local result = func
        local params = ""
        if args ~= nil then
            for index, arg in pairs(string.split(args, ',')) do
                params = params .. " * @param type " .. string.trim(arg) ..  "\n"
            params = params .. " *" .. "\n"
        --  * @param type $a
        --  * @param type $b
        --  * @return type
        local result = "";
        result = result .. "/**"               .. "\n"
        result = result .. " *"                .. "\n"
        result = result .. params
        result = result .. " * @return type"   .. "\n"
        result = result .. " */"
        if current == true then
            MoveLineUp()
        MoveLineHome()
        cursor_save()
        -- add the result to the document without using smart indenting
        write(result, false)
        cursor_restore()
        message("No function details found!")
