Changing keyboard mapping
parameter
Post by parameter »
Hi, I found where to change keyboard mappings for things that are only keyboard related, but I'd like to change the Alt+click and Control+click behavior. Specifically I'd like to reverse them.
In other editors I've used, Alt+click is used for rectangular (block) selection. That seems to be mapped to control+click in Zeus.
I'm new to Zeus so this may be a really simple thing, but please tell me how to do it anyway.
Unfortunately this is not possible :(
The only form of mouse configuration that is possible is using the Options, Editor Optins menu to select Default Mouse Marking mode.
The latest Zeus version now allows macros to be attached to the mouse click and double click events. For more details refer to the Options, Editor Option s menu and select the Triggers panel.
