Using Zeus with Visual C++ 2010 solutions (*.sln)?
craig.martell
Post by craig.martell »
ALL:
I am new to Zeus, but all of the great comments have made me excited about trying it. I currently use VC++ 2010 but want an editor I can configure more to my liking.
I am able to open a VC++ 2010 solution file, and all of the files are included. The problem comes when I try to build to solution. I get the following error:
c:\Path to Solution called Templates\Templates.vcxproj (3,14): error MSB4066: The attribute "Label" in element <ItemGroup> is unrecognized.
It compiles fine in both Visual Studio and Slickedit.
Any ideas?
Craig
Hi Craig,
FWIW I use VC++ to build and debug Zeus but I do most of my coding inside of Zeus.
If you want to configure Zeus for Windows C/C++ development at a minimum I would recommend:
1) Configuring the Quick Help for the MSDN: http://www.zeusedit.com/zforum/viewtopic.php?t=2833
2) Setting up Quick Help for any other third party libraries you may use: http://www.zeusedit.com/zforum/viewforum.php?f=7
3) Setting up the code templates to match you coding style: http://www.zeusedit.com/zforum/viewtopic.php?t=40
But that is just the start since there are lots of ways to tweak Zeus ;)
Any ideas?
Luckily, the setup required to get Zeus to work with VC++ should be fairly easy.
Here is a link that descrides the two steps required to make this work: http://www.zeusedit.com/zforum/viewtopic.php?t=2707
PS: These instructions should work, but please let me know if you find they don't help or if you run into any other issues getting VC++ working from inside of Zeus.
craig.martell
Excellent! That worked great. I will now start exploring how to make Zeus work best for me!!
