Agent SVN and TestComplete
I am using a software called TestComplete when I am trying to add my project from TestComplete with help from SVNAGent I get a pop-up "Agent SVN Project binding details" and pushes the "List" button besides the project I get the following screen:
Projects in Repository: file:///C:/SVN_repository/SVNProject
1 mattkz okt 31 14:26 ./
1 mattkz okt 31 14:26 branches/
1 mattkz okt 31 14:26 tags/
1 mattkz okt 31 14:26 trunk/
Fully Qualified Project Locations
If the projects above where imported into the repository using
the 'trunk' postfix naming convention then the locations of these
projects need to include the trunk postfix details in order to
fully qualify the name.
Here is an example of a fully qualified project location:
1 mattkz okt 31 14:26 branches/trunk/
I have tried a lot of combinations in order to define my project but I have failed. What shall I answer ?
/karin
/karin
Hi Karin,
To test this out I created the following SVN repository:
I then created the following test project:
I then used Zeus to import the project into the Subversion repository. and after the import this was the repository listing looked like:
To bind to the project in Zeus I use the same bind Agent SVN dialog and these are the details I entered:
But notice I set the repostitory path to be this:
whereas you set it to be this:
If I use the AUX Path button found in the Agent SVN bind dialog and set it to C:/SVN_Repository/SVNProject then my project list becomes this:
So I think to get you binding to work you need to do the following:
(1) Bring up the Agent SVN bind dialog
(2) Use the AUX Path button and set the repository to be the root folder location so in your case it becomes this:
(3) Change the other binding details to be:
Directory of c:\SVN_Repository
03/11/2011 10:28 AM <DIR> .
03/11/2011 10:28 AM <DIR> ..
03/11/2011 10:28 AM <DIR> conf
03/11/2011 10:33 AM <DIR> db
03/11/2011 10:28 AM 2 format
03/11/2011 10:28 AM <DIR> hooks
03/11/2011 10:28 AM <DIR> locks
03/11/2011 10:28 AM 234 README.txtCode: Select all
Directory of c:\projects\SVNProject
03/11/2011 10:31 AM <DIR> .
03/11/2011 10:31 AM <DIR> ..
03/11/2011 10:33 AM 496 file1.txt
03/11/2011 10:29 AM 396 file2.txt
03/11/2011 10:29 AM 112 file3.txt
03/11/2011 10:32 AM 3,977 SVNProject.zpi
03/11/2011 10:32 AM 289 SVNProject.zwiCode: Select all
3 jussij Nov 03 10:39 ./
3 jussij Nov 03 10:39 SVNProject/
3 jussij Nov 03 10:39 SVNProject/trunk/Code: Select all
03/11/2011 10:33 AM .svn
Project: SVNProject/trunk/
Local Path: C:\projectsCode: Select all
C:/SVN_RepositoryCode: Select all
C:/SVN_Repository/SVNProjectCode: Select all
Projects in Repository: file:///C:/SVN_Repository/SVNProject
1 jussij Nov 03 10:51 ./
1 jussij Nov 03 10:51 trunk/
1 jussij Nov 03 10:51 trunk/trunk/(1) Bring up the Agent SVN bind dialog
Local Path: C:\projectsI am interested in this topic, for my small group uses TestComplete. We inherited TortoiseSVN connecting to Subversion 1.6.6 on a Linux server. TortoiseSVN and TestComplete are NOT compatible, but TesatConplete advertises to be compatible with any MSSCCI compatible client. We have tried an evaluation copy of TamTam, but have not had success.
Your AgentSVN seems to be geared toward Microsfot products and windows repository. I was lost trying to determine how to enter aux path, project name, etc. in our environment?
Have you had any other users with success using your AgentSVN connecting to a LInux server repository?
Thanks.
Thanks.
This means that it should work or at least that it can be made to work.TestComplete advertises to be compatible with any MSSCCI compatible client.
With your help I'm more than happy to try and make this work.
One of the problems with the MSSCCI is it does'nt define the user interface.I was lost trying to determine how to enter aux path, project name, etc. in our environment?
So all IDEs seem to have a different set of GUIs.
But I am going to assume TestComplete works in a similar way to Microsoft tools.
If this is the case this is what I would suggest.
(1) Use the AgentSVN configuration utility and setup the AgentSVN as follows:
http://www.zeusedit.com/agent/ssms/imag ... re_svn.png
This will use the local folder as the location for the SVN repository.
(2) Also turn on the help debug option from the previous step.
(3) If you then see this message box:
The following Subversion components where not found in the PATH of the local machine:
svnadmin.exe
svn.exe
For this software to work these Subversion components need to have been installed...These are the SVN command line tools and to fix this you will need to download an installer for these components from this location:
http://sourceforge.net/projects/win32svn
(4) Next create a new TestComplete project.
Then try to add that project to the local SVN repository created earlier using some sort of Add to Source control menu.
If the add step works you should see the project in the local SVN repository.
(5) The final step would be a bind process.
In the Microsoft world this bind process looks like this:
http://www.zeusedit.com/agent/ssms/imag ... mplete.png
AgentSVN connects to the repository using the svn.exe command line tool so it should be able to connect to any SVN repository.Have you had any other users with success using your AgentSVN connecting to a LInux server repository?
But the tricky part is first making sure it actually works with TestComplete
That is why I would recommend first starting with a very simple local repository as shown above.
Once it has been shown that TestComplete works with a local SVN repository it should be very easy to point it to a remote repository.
From karin orignal post it appears like he could actually see the repository from inside TestComplete via AgentSVN which means it was probably close to working.
But unfortuately with no access to TestComplete at this end it is hard to test this and unfortunately karin did no reply to my post
So if you follow the steps above and run into trouble could you please send me the log file produced via an e-mail (see the e-mail button below).
Am trying to set up my local repository using your directions. I do not know how this will work with Linux server accessing myt local disk for a trial repository.
I also see the SVN Ignore section, to which I am trying to add specific TestComplete files. THe TestComplete execution log files are in a */Log directory. The log names are in the form "m_d_2012_h_m xM_ss_ms", where m = 1 or 2 digit month
d = 1 or 2 digit day
h = 1 or 2 minute hour
m = 1 or 2 digit minute
ss = 1 or 2 digit second
ms = 1-3 digit milliseconds
Can this accept wildcards in the form of a regular expression, like
"*_2012_* [AP]M_*"?
Thanks.
"*_2012_* [AP]M_*"?
Thanks.
From my prior post, I thought I could remove that regular expression later if I need to. I provided AgentsSVN with the folder C:\QA_SC_Repository, which was empty. When I brought up TestComplete using an old project NOT on my local system, TestComplete saw AgentSVN and brought me to the Project Binding Details screen.
The project field is empty, and List says there are 0 projects.
The AUX Path field contains "file:///C:/QA_SC_Repository".
The Local Pathcontains "Y:\resetEMDS_1" (the TestComplete project)/
Apparently I need to populate the "C:\QA_SC_Repository" somehow?
AgentSVN will create the local repository.Am trying to set up my local repository using your directions.
This process should be as simple as selecting the file protocol and select a local repository folder.
If this does not create a local repository then here is the first problem
I'm now a little confusedI do not know how this will work with Linux server accessing my local disk for a trial repository.
If you look at the PowerBuilder example, the SSMS example or the Visual C++ and Visual Studio examples in the AgentSVN help file you will see a pattern.
All these example try to do is try to test if AgentSVN, the IDE and Subversion can work together.
They do this by using the simplest possible configuration model which is a local SVN repository using the file protocol.
So to check to see if TestComplete works with AgentSVN and Subversion the simplest possible test should likewise be:
1) Configure AgentSVN to use a simple local file protocol SVN repository
2) Make sure that AgentSVN created that local file repository (something like c:\projects\repository\)
3) Connect TestComplete to AgentSVN
4) Create a simple local file project in TestComplete (something like c:\projects\MyTest\)
5) Try to add that c:\projects\MyTest\ project to SVN repository using the AgentSVN Import Wizard.
6) Make sure the TestComplete c:\projects\MyTest\ project is bound to that repository
7) Now see if I can check add/check out/check in/revert files in that c:\projects\MyTest\ test project
These are basically the same steps that I outlined earlier.
Unless I am missing something, for this simple test there should be no Linux server involved at all.
Once the test is complete and has proven to work it should be very easy to just re-point the SVN repository.
Now I have never used TestComplete so I might be wrong in all of this, but this is what I would be expecting to see.
I would leave the file ignore filters for now.The TestComplete execution log files are in a */Log directory.
Because inside the import Wizard itself (which shows when you try to add a project to the repository) there is an additional option to ignore folders.
So at this step of the process you can just ignore the entire Log folder.
These ignore filters are used by the svn.exe command line tool itself.Can this accept wildcards in the form of a regular expression
I have never looked how the svn.exe uses these filters but I suspect they are standard command line file filters (not regular expressions).
I would much prefer that you create a new local repository using the AgentSVN configuration tool.When I brought up TestComplete using an old project NOT on my local system
Here is why.
1) The AgentSVN uses the Subversion svn.exe utility: http://sourceforge.net/projects/win32svn
2) This svn.exe utility has to be installed for AgentSVN to work.
3) If your test repository is not at the same version number as the svn.exe utility it is not going to work.
4) If your test repository has been permissioned with security settings then you won't be able to connect to that repository until you setup the correct user profiles.
And the list goes on. But if you create the local repository it is guaranteed to work
This is good. It is a sign that TestComplete is in fact MSSCCI compliantTestComplete saw AgentSVN and brought me to the Project Binding Details screen.
What you are seeing is the binding dialog. This lets you bind a project to a SVN repository.
What does the List button show when you click it.The project field is empty, and List says there are 0 projects.
It should list the projects/folder/files in that repository.
Why is your working copy set to this Y:\ drive locationThe Local Path contains "Y:\resetEMDS_1" (the TestComplete project)
This looks like a server folder location, not a local folder location.
Once again if you don't have read/write access to this folder it is not going to work.
I would expect that local working copy be on your local machine.
I would expect this to be something more like this:
c:\projects\resetEMDS_1Code: Select all
Apparently I need to populate the "C:\QA_SC_Repository" somehow?To just see if TestComplete is going to work with AgentSVN I would highly recommed you try steps 1) through steps 7) above on a local machine using new local repository using the file protocol.
Then as soon as any one of those steps fails just send me the log file.
NOTE: You can access the log file using the AgneSVN Configuration utility.
First my apologies for the confusion. I have never posted anything using a forum like this (I probably have underwear older than you).
You referred to the PowerBuilder example, which said
[quote]For Agent SVN to work correctly requires Agent SVN, Subversion and Microsoft SQL Server Management Studio all to be installed and configured correctly[/quote]
I have no Subversion anywhere except on a Linux server. Do I need to get and install a local version on my Windows 7 system?
In the directory I created on my C: drive (C:\QA_SC_Repository) I see folders conf, db, hooks, and locks, as well as README.txt and a format file. I see nothing about any TestComplete project. Has the local repository has been created?
I navigated and executed the Agent SVN Configuration from the Start menu. The SVN Project Manager field was left blank, I enter "C:\QA_SC_Repository" in the Folder field, and "C:\program files\collabnet\subversion client\diff.exe" "$f1" "$f2" in the Command line field, and the protocol field was set to "Local File(file://)". I already described my entries in the SVN Ignore field.
[quote] If your test repository is not at the same version number as the svn.exe utility it is not going to work.[/quote]
The svn.exe we obtained from CollabNet and it is version 1.7.4. The subversion version is 1.6.6, according to the server admin.
Given those details, I opened an existing TestComplete project from my Y: drive, that I want to put inot my new repository C:\QA_SC_Repository.
Using TestComplete:
[list]Select File->Source Control->Add Project Suite, which brings up the Select SCC Provider dialog.
Select AgentSVN and select OK, which brings up the "Agent SVN - Project Binding Details" window.
Select List button, and the "Agent SVN - Repository Tree" says projects in repository is 0. (This is what prompted my question Do I need to populate this somehow).
[/list]
At this point I do not know what to enter in the fields. The List is empty, and complains about that. I entered "HRM_AgentSVN_Smoke/trunk/" and a popup said the project does not exist in the repository. I entered "C:\HRM_TestSVN_Working" in the Local Path field.
Using TestComplete:
[/list]
Don't bet on it. I myself have been in the programming game for over two decadesI probably have underwear older than you.
On your Linux server you have will be running a Subversion server.I have no Subversion anywhere except on a Linux server.
On you local machine you will be connecting to this Subversion server using a Subversion client.
In your case the Subversion client is most probably TortoiseSVN but it is still a client.
In the case of AgentSVN, it connects to the server using the svn.exe Subversion client.
Yes.Do I need to get and install a local version on my Windows 7 system?
This link contains the Subversion client installer: http://sourceforge.net/projects/win32svn
Now what might be creating some confusion is the svn.exe has a bit of a split personality.
The svn.exe is a client but it can also connect to a file protocol SVN repository without needing a Subversion server.
In other words by creating a local machine repository using the file protocol, means you can basically run Subversion without needing a full blown Subversion server.
This is one of the reasons I suggest doing all the initial testing with this type of setup.
Did you create this usg the AgentSVN Configuration Utility.In the directory I created on my C: drive (C:\QA_SC_Repository) I see folders conf, db, hooks, and locks, as well as README.txt and a format file.
The AgentSVN does not actually create the SVN repository, but instead it uses the svnadmin.exe tool that comes as part of the Subversion client installer mentioned above.
If you did create the repository using the AgentSVN Configuration Utility then you will now have an empty SVN repository.Has the local repository has been created?
If you did not, then just delete the repository and use the AgentSVN Configuration Utility to create the repository.
That is the tool I am talking about.I navigated and executed the Agent SVN Configuration from the Start menu.
That sounds perfect.The SVN Project Manager field was left blank, I enter "C:\QA_SC_Repository" in the Folder field, and "C:\program files\collabnet\subversion client\diff.exe" "$f1" "$f2" in the Command line field, and the protocol field was set to "Local File(file://)". I already described my entries in the SVN Ignore field.
Now if you delete the C:\QA_SC_Repository folder then open up the Configuration Utility it will create a new repository for you.
This may well cause issues.The svn.exe we obtained from CollabNet and it is version 1.7.4. The subversion version is 1.6.6, according to the server admin.
If CollabNet changed the database schema between these two version then that client will not work with that server.
But using the local test described above, that will not matter at this time since you will not be going anywhere near that Linux repository.
You will be talking to your local repository.
Unfortunately you will not be able to do this, because this is not how Subversion worksGiven those details, I opened an existing TestComplete project from my Y: drive, that I want to put inot my new repository C:\QA_SC_Repository.
For the Subversion client to work it must have a valid working copy.
Now your Y: working copy will be pointing to your Linux Subversion repository and there will be now way you will be able to point it to the C:\QA_SC_Repository repository.
If instead you follow the seven steps that I outlined what should happen is this:
1) AgentSVN will create the local repository
2) AgentSVN will import a new project into the repository
3) AgentSVN will create a valid working copy for that project
For this testing stage you will need to create a new dummy test project, or you will need to remove the svn details found in that folder.
Now you don't want to be removing svn details from you y: folder because you will be corrupting that working copy.
It is much easier, much safer to just create a new test project.
As I said before, once you are sure AgentSVN and TestComplete actually working, only then it is time to try to connect to a real Linux svn repository.
What is happening is you are confusing AgentSVN and svn.exe.At this point I do not know what to enter in the fields.
On the one hand you are pointing AgentSVN to the empty SVN repository is found here: C:\QA_SC_Repository
On the other hand you are then opening a TestCase project that contains a valid SVN working copy and that working copy is pointing to the Linux SVN repository.
So to have any chance of getting this to work you have to either:
1) Forget doing any local repository testing and connect directly to the Linux Server
2) Forget the Linux Server for now and do the much simpler local machine repository test
As I said befor IMHO the second option is the simplest and easiest option.
I have been around since getting out of college in 1968.
OK, I have on MY windows 7 system both the 1.7.4 CollabNet SVN command line client svn.exe and the TortoiseSVN client provided by my company. The TortoiseSVN about indicates it is 1.7.6 and the Subversion is 1.7.4 (which is different from the 1.6.6 our server admin reported). I do do svn.exe and svnadmin.exe (and others) in two different client trees.
I Deleted and recreated the repository using the "svnadmin create" command line presented. I then opened TestComlete project suite "C:/HRM_TestSVN_Working/SS_HRM_Master_PreSmokeTest". Attempting to add this to source control (File->Source Control->Add Project Suite) allowed me to choose AgentSVN and then I again got to the Project Binding Details screen. Again, the list is empty (prject count is 0); if I try to enter a "name/truck/" as indicated on the popup that tells the project list is zero, then it tells me that the project is not found in the repository.
I am sure this is a YAMS (Yet Another Mosley Screwup), but I am unsure of how to proceed.
BTW, thanks for your assitance; it is certainly more than AutomatedQA (SmartBear) provided.
I do have Microsoft SQL Server Management Studio on my system to connect to DB servers. My Subversion admin confirmed that the version is 1.6.6, which is older than the clients (CollabNet and TortoiseSVN) I have.
I could download a copy of CollabNet Subversion Edge for my 32-bit winodws 7 system and have everything local for this test, but I do not know how to configure Apache or Subversion.
So you have a few decades on meI have been around since getting out of college in 1968.
Ok that looks perfect.OK, I have on MY windows 7 system both the 1.7.4 CollabNet SVN command line client svn.exe and the TortoiseSVN client provided by my company.
I'm not sure what issues this is going to cause if any, but for this initial test it does not matter.The TortoiseSVN about indicates it is 1.7.6 and the Subversion is 1.7.4 (which is different from the 1.6.6 our server admin reported).
Excellent.I Deleted and recreated the repository using the "svnadmin create" command line presented.
What happened was AgnetSVN detected the loction provided did not contain a valid SVN repository so it asked for permission to create one.
Naturally, later on when you re-point the location to the real Linux server SVN location AgnetSVN will detect that location as a valid SVN repository.
Perfect.I then opened TestComlete project suite "C:/HRM_TestSVN_Working/SS_HRM_Master_PreSmokeTest".
This is good.Attempting to add this to source control (File->Source Control->Add Project Suite) allowed me to choose AgentSVN and then I again got to the Project Binding Details screen.
It looks like we have run into our first TestComplete/AgentSVN incompatiblity
Because this is a new repository and you are doing an Add to Source control you should have been presented with the AgentSVN Import Wizard.
Now to detemine why this is not working please do the following:
1) Make sure TestComplete is not running
2) In the AgentSVN Configuration turn on the help debug option
3) Start TestComplete, open your test project
4) Try to add the project to source control
5) Close TestComplete
6) Go back to the AgentSVN Configuration and click on the ... button to open the log file
7) Add the log file to e-mail as an attachment and send it to me (e-mail button below)
That is to be expected since the repository is new.Again, the list is empty (prject count is 0)
I'm more than happy to support AgentSVN and I am very happy with your persistenceBTW, thanks for your assitance; it is certainly more than AutomatedQA (SmartBear) provided.
If your interested you could run through this tutorial: http://www.zeusedit.com/agent/ssms/ms_ssms.htmlI do have Microsoft SQL Server Management Studio on my system to connect to DB servers.
In fact you are half way through this tutorial already (i.e. just use the same local repository).
This will connect Microsoft SQL Server Management Studio to AgentSVN.
I'm almost certain this is going to work since your local machine setup seems to be correct.
It might be a good idea to in fact do the tutorial since it will give you a feel for how AgentSVN works.
For example you will get to see how the AgentSVN Import Wizard works.
But once again, all I can say is try to follow and understand each of the steps in the tutorial.
You will find the steps in this SSMS tutorial will mirror the steps you will be taking in TestComplete, that is once I get AgentSVN working with TestComplete.
NOTE: I think SSMS itself contains an MSSCCI bug and there is a work around to this bug at the end of the tutorial.
