Function List - color change not working
paul3d
Post by paul3d »
When I select 'Control' - G (Function List in brief emulation)
I can't seem to change the Colors? - it always keeps the same colors
I select Options->Color Options and select the colors - but they don't change
Paul
Hi Paul,
The color settings for anything but the default document window can be a bit confusing :(
Here are the steps needed to change the Function list colors:
  1. Use Control+G to create a windows list
  2. With that window active use the Options, Color Options menu
  3. Select the General Output View from the Display View drop down.
  4. Now change and apply the color options available as per normal.
In other words each Display View has it's own set of colors which can be a bit confusing bit.
To add to this confusion, all but the Document View are shared across all document types.
In other words if you are changing the Document View from the Display View drop down then you will be changing the colors for that document type only, but for any other Display View option you are changing the colors for all document types.
paul3d
Post by paul3d »
That worked!
Thank you!
Paul
