LUA Debugger
pwdiener
LUA Debugger
Post by pwdiener »
Jussi,
A couple questions/observations regarding the LUA debugger:
1) I was using it yesterday, and after some effort was able to get it working reasonably well. However, it failed every time it hit one of the built-in macro functions (debug_output, screen_output_disable, etc.). I believe the message said something about a nil value. Is this as expected or have I still not got it working completely?
2) The next time ran a compile (which I run through a .CMD file), I got a Zeus internal error dialog box. I could not terminate normally - I had to kill Zeus from task manager. There isn't necessarily a cause-effect relationship here, but I haven't had one of those for a long time. I'll send you the .log and .dmp files separately in case they help.
Bill Diener
The Lua debugger can not debug Zeus macros :(
The debugger only works for fully external macros.
