Line Folding Macro
Line Folding Macro
The Lua macro below allows the user to fold away certain lines.
The macro works by asking the user for a search string and then any line that contains the search string which is also a fold point will have its fold closed.
--        Name: Line Folding Macro
--    Language: Lua Macro
-- Description: This Lua macro will prompt the user search string and
--              close any line fold points that contain that string.
    if document > 0 then
        -- get the last search string
        local last_search = get_global_string("FIND_TEXT", true)
        -- ask for a user supplied decimal number
        local pattern = user_input("Search Pattern:", last_search)
        if string.len(pattern) > 0 then
            local FOLD_BEGIN = 2
            -- save the last search string
            set_global_string("FIND_TEXT", pattern, true)
            -- disable screen updates
            -- save the current cursor
            cursor_save()
            -- open up all fold points
            FoldingOpenAll()
            local line_total = get_line_count()
            -- search the whole file for the pattern
            for i = 1, line_total, 1 do
                -- get the line text
                local line = get_line_text(i)
                if ((string.len(line) > 0) and (string.find(line, pattern) ~= nil)) then
                    -- move to the line found
                    set_line_pos(i)
                    -- check for a fold point
                    local fold_style = get_line_folding(i)
                    if fold_style == FOLD_BEGIN then
                        -- close the begin fold found
                        FoldingLineClose()
            -- restore cursor
            cursor_restore()
            -- restore screen updates
            -- user feedback
            message("Action completed for pattern: '" .. pattern .. "")
