Workspace Project Tag files
mgag
Post by mgag »
I have a workspace with two projects in it, A and B. When I search the tags database, results from both project A and B are shown, even though only project A is "active". In the WorkSpace->Options->TagsDatabase neither project has any installed files. The Available Files shows A.zdb and B.zdb. The text above says "Select any extra database files... Projects in the workspace are automatically included and don't need to be added."
So it is true that in a workspace all project tag databases are loaded? (probably a rhetorical question given thats the way it behaves).
In my setup, the projects are actually different clients of the same codebase; each project is a different sync. When I search a tag, I have to sort thru the right one because I get multiple hits (one for each client (each project)).
Is it possible, and/or is it a good idea to have a check box that allows only the active project tags database to be loaded?
This feature has been added to the latest release found here: http://www.zeusedit.com/forum/viewtopic.php?p=5306
Post by Guest »
This is working Thanks.
regards,
mgag
