New Tab in Navigator
petar12345
Post by petar12345 »
Hi
I have many Templates and many macro script . I have problem when need chose one. I put in Pop up menu 10 of most need macro. But I have problem with rarely used macros. What is file name, many same macros with small differences.
Can You make new Tab in navigator named "Macro script" with properties:
- It is like Workspace Tab (have folders and files)
- It is in file in Zeus\zConfig folder and it's name is: Zeusxxx-scripts.zpi
- It is associate with document tipes (xxx - document tipe)
- User can arange it like Workspace
- Right mouse click on file name in this tab have options: execute, edit
open file location.
Can you change navigator tab templates in same way.
Can you in Workspaces tab add properties open file location when occure right mouse click on file name.
By from Croatia.
Hi Petar,
This is a a good idea and it should be possible to implement.
Hopefully it is also easy to implement. I will add this to the Zeus todo list ;)
I will add this also to the Zeus todo list ;)
Doesn't the Open in Explorer option do something like what you want :?:
It will open the explorer in the folder of the selected file and from there you can then either double click or drag the file into Zeus.
Also there is the FileOpenEx keyboard function. This will function open the file open dialog using the directory of the currently open file ;)
So for example you could open the file in Zeus with a click from the navigator and then use this function to open the file open dialog in this new directory.
I am a little reluctant to add too many items to these drop downs as there are quite a few items there already :(
petar12345
Hi Jussi
jussij wrote:Hi Petra,
Petra is female name in Croatian. :?
My name is Petar (male).
jussij wrote:Doesn't the Open in Explorer option do something like what you want
It is exactly what I ask. :D
Thank You.
My name is Petar
My apologises Petar.
I seem to be suffering from a bad case of dyslexicia :(
This latest release adds Macro, Template and Tool panels to the navigator ;)
The latest release found here: http://www.zeusedit.com/forum/viewtopic.php?p=5306
