I just installed Zeus and liking it very much so far. But since I plan to use it mostly for "non-standard" language, found the need to do lot's of customizations, code folding being one of them. I'd appreciate much if you can add the support for it. Stata is a statistical analysis software and has it's own scripting language, here's example:
Extension: .do; .ado; .class
Line Comment1: //
Line Comment2: *
Block Comment: /* */
Case Sensitive: yes
Begin: program
  End: end
Begin: class
  End: }
Begin: if
  End: }
Begin: else
  End: }
Begin: forvalues
  End: }
Begin: foreach
  End: }
Begin: while
  End: }
Begin: quietly
  End: }
Begin: noisily
  End: }
Begin: capture
  End: }
stata has two types of end-line delimiters cr and ";" so it would be nice if a multiline commands can be folded as well (more examples below)
Some sample Code:
program define matrix_capp
	version 8
	syntax anything [, miss(str) cons ts sort]
	local b12   : word 1 of `anything'
	local colon : word 2 of `anything'
	local b1    : word 3 of `anything'
	local b2    : word 4 of `anything'
	if `"`colon'"' != ":" {
		// example of a command spaning multiple lines
		display as err ///
			`"colon expected, `colon' found"'
		// this is the same as - display as err `"colon expected, `colon' found"'
		exit 198
	// will use this part later
	tempname TMP
	local cnames
	forvalues j = 1/2 {
		forvalues i = 1/`=colsof(`b`j'')' {
			matrix `TMP' = `b`j''[....,`i']
			local cnames `"`cnames' "`: colfullnames `TMP''""'
	if ~missing("`sort'") {
		tempname TMP bb
		local rfullb1
		local rfullb2
		forvalues i=1/`=rowsof(`b1')' {
			matrix `TMP' = `b1'[`i', ....]
			local rfullb1 `"`rfullb1' "`: rowfullnames `TMP''" "' // we can't trust rowfullnames for multi-word names
		forvalues i=1/`=rowsof(`b2')' {
			matrix `TMP' = `b2'[`i', ....]
			local rfullb2 `"`rfullb2' "`: rowfullnames `TMP''" "'
		local rfullb : list rfullb1 | rfullb2
		matrix `bb' = J(`nr', `nc1' + `nc2', `miss')
		forvalues i=1/`nr' {
			local ii = rownumb(matrix(`b1'), `"`: word `i' of `rfullb''"')
			local ii = rownumb(matrix(`b2'), `"`: word `i' of `rfullb''"')
			if ~missing(`ii') matrix `bb'[`i', `nc1' + 1] = `b2'[`ii', 1...]
		matrix rownames `bb' = `rfullb'
		matrix colnames `bb' = `cnames'
		matrix `b12' = `bb'
		exit
	matrix colnames `bb'=`cnames'
	matrix `b12' = `bb'
// example with ";" delimiter
#delimit ;
		graph combine gic_total gic_urban gic_rural,
				imargin(0 1 0 0) ysize(6) xsize(8) iscale(0.8)
				graphregion(color(white) style(none) margin(0 0 0 0) lstyle(none))
				plotregion (color(white) style(none));
zura
