Syntax Highlight Line Containing Cursor
kleinfelter
Post by kleinfelter »
When I enable "Highlight line containing cursor" I lose syntax coloring on that line. Is there a way to highlight the line containing the cursor without losing syntax coloring? For example, my normal background color is very dark blue. I'd like to highlight the line containing the cursor by making the background a *slightly* lighter shade of blue.
Unfortunately there is no way to stop the loss of syntax highlighting :(
Using the Options, Editor Options menu to enable the Highlight line containing cursor option and then using the Options, Document Types menu to edit the document type, switching to the coloring section and changing the line cursor, category only allows you to define the background and foreground colors for the line that contains the cursor.
This is an all or nothing feature :(
