Agent SVN and TestComplete
Here is a tutorial on how to use TestComplete and Agent SVN: http://zeusedit.com/agent/tc/tc.html
s.stirley
Post by s.stirley »
I am having similar issues with connecting TestComplete. I have it all working up to Step 3 in the tutorial, adding a project to source control. When I go through this step and try to commit it I get warnings about 'scc_opt_createifnew' not being set and the path not known.
I've tried adding some of the paths manually to the repository, but still receive the same messages.
The MS documentation seems to suggest this flag can be passed in the SccOpenProject call, but I guess AgentSVN doesn't do this by default ?
Any help greatly appreciated - we're starting a large project and will be buying licenses if we can get this to work with Subversion.
s.stirley
Post by s.stirley »
PS. the errors appear after the 'Project Binding Details' dialog, and the confirmation dialog to create new project never appears
Please make sure you are running Agent SVN 2.00 or better.
This latest version was only released a few hours ago and it is the version used in the tutorial.
The previous versions of Agent SVN did not work with TestComplete.
s.stirley
Post by s.stirley »
I've just downloaded v2.0 and it works great now !
Thanks for the quick response. We'll now evaluate it with TestComplete for our needs.
Simon
hmosley
AgentSVN 2.0 status
Post by hmosley »
According to the last post, the version 2.0 of AgentSVN is working despite the lack of assistance from SmartBear.
Do you have any other users with the same success?
Do you anticipate further changes?
Thanks for all your efforts.
Unfortunately as I'm not overly familiar with the workings of TestComplete I really can't give you a measure of how well it works :(
From what I can tell it is working to some extent.
It is a bit to early to tell. The version 2.00 is only a few days old.
I suspect so. Time will tell.
I am planning to use the TestComplete page to track what does and does not work: http://zeusedit.com/agent/tc/tc.html
For example that page already list the Get Latest Version issue.
The latest version of the Agent SVN now has much better support for Test Complete.
