Workspace not working correct on windows 2k Server
Just a quick note, tried the trial software on windows 2k server. When i create a new work space using the Workspace Builder Tool when i finally finish creating the workspace i dont get the Files folders, eg no Header, no Source etc.. The entire tree doesnt get created or displayed. Not sure if this is an issue with w2k server or the fact its running under virtual PC. Thought id mention it though
All I can suggest is
- Check that the Zeus Help About dialog and make sure the version you are running is the lastest Zeus 3.95x release. If not then apply this patch:
http://www.zeusedit.com/forum/viewtopic.php?t=770 - Check the contents of the *.zpi and *.zwi Project and Workspace files that should have been created by the builder. Maybe the location the Builder is trying to create these files is read only
These are just XML files so you can open then in Zeus as a text file.
This issue is probably DEP related.
To fix this issue you need to do the following: http://www.zeusedit.com/forum/viewtopic.php?p=5622
The latest version of Zeus found here has the DEP flag turned on which hopefully means it now runs fine on Windows 2k Server:
http://www.zeusedit.com/zforum/viewtopic.php?p=5622
