I still use the Microsoft "M" text editor in DOS - I have just started my first large Windows project at work and would like to know if emulation of this editor is possible.
In short - the feature I use most often is alt-a text marking which can mark both lines and columns depending on the start and end positions of the cursor: Line Marking - set cursor at top of text region, hit alt-a, move cursor straight down. Column Marking - set cursor at a corner of column region, hit alt-a, move cursor to opposite corner.
Any chance this could be supported?
thanks
-pj
Hi PJ,
As I am not familar with the M editor, I am not sure 100% sure if this macro will provide the functionality you are after
But in any case you need to save the code below to the zScript\mark.lua file, then bind the macro to the Al+A key:
local key_up = 2490368
local key_down = 2621440
local key_left = 2424832
local key_right = 2555904
-- wait on the next key press to see which marking mode is required
local key = keyboard_input()
if (key == key_up) then
-- set block marking mode
MarkBlockSet()
-- maybe this is what is needed
--MarkLineSet()
-- move the cursor
MoveLineUp()
-- this is only for debugging
message("Up key column marking")
elseif (key == key_down) then
MarkBlockSet()
-- move the cursor
MoveLineDown()
message("Down key column marking")
elseif (key == key_left) then
-- set column marking mode
MarkColumnSet()
-- move the cursor
MoveLineLeft()
message("Left key column marking")
elseif (key == key_right) then
MarkColumnSet()
-- move the cursor
MoveLineRight()
message("Right key column marking")
message("Marking cancelled")
