I have been using your software for sometime and just an hour ago I bought the upgrade to the latest version.
The reason I upgraded was because of the Unicode/UTF-8 support.
Unfortunately I tried opening a UTF-8 document but I still get strange symbols instead of greek letters. The only option for UTF-8 that I discovered was in the Save as option.
Could you please shed some light on this as I love this editor and I want to keep using it.
By the way I tried sending an email to info@zeusedit.com which you have on the site but it bounced back..
Yes it displays properly (apart the square symbols that appear in place of new lines in UNIX format files). But otherwise the greek letters display properly
I am not sure to tell you the truth
I know that I can view the file in several editors that support UTF-8.
Is there any way to check if the file contains double byte characters?
