Setting up a R Development Environment for Windows
NOTE: It is strongly recommended usign the lastest Zeus IDE found here: https://www.zeusedit.com/download.html
That latest version comes with a R Document Type definition, but users of older versions can still manually create that definition.
The R mome page is found here: https://www.r-project.org/
Download and run the Windows installer is found here: https://cran.r-project.org/bin/windows/base/
NOTE: At the time of writing the R-4.3.1 for Windows (79 megabytes, 64 bit) installer was used for this test.
Setting up the PATH
That 64 bit installer defaults to installing to this folder location:
C:\Program Files\R\R-4.3.1\bin
Before the software can be used this location needs to be added to PATH environment variable.
For information on how to do this refer to the following link: viewtopic.php?t=6176
Testing the Setup
After making the PATH changes, start the Zeus IDE and use the Tools, DOS Command Line menu to run the following command:
Rscript.exe --version
Running that command should result in the following output:
      Zeus IDE - Version 3.99am
      Copyright (c) Xidicone P/L 2023  All rights reserved.
Rscript (R) version 4.3.1 (2023-06-16)
If that output is not produced check the path settings made earlier to make sure they are correct.
Creating a R Program
With the Zeus IDE installed, select the R Template option as shown below:
The attachment R-template.png is no longer available
Create a new test.r file usign the code shown below:
hello <- function( name ) {
    sprintf( "Hello, %s", name );
hello("world")
With that file as the active document use the Macros, Execute menu to run this script as shown in the image below:
The running of that script will result in the following tool output window:
Creating a R Grapical Program
Consider this test.r file that creates a graph using the plot function:
# NOTE: The plot function creates a file called Rplots.pdf
x <- seq(-2*pi,2*pi,0.1)
plot(x, sin(x))
Running that R script using the Macros, Execute menu creates a PDF graph file and the macro will display that file in the browser as shown below:
NOTE: For details on how this works refer to the Zeus r_exec.lua found in the zScript folder.
