Can't change Navigator colors
Jack
Post by Jack »
I just updated to version 3.98zm-Beta15. The new color scheme for the navigator I find annoying. I tried changing it under the Misc tab in the editor options. Changing the settings has no effect. When I apply to settings, I do get a dialog warning complaining about Bash command lien provided doesn't exist. I don't know if that is the problem or not.
Re: Can't change Navigator colors
In that same Options, Editor Options menu, Miscellaneous panel can you try setting the Bash Command Line edit field to nothing.
This setting defaults to assume the Windows Subsystem for Linux (WSL) has been installed and hence the reason you are getting this error message.
By removing that WSL entry this should also eliminate the error message.
Jack
Post by Jack »
Clearing the BASH entry eliminated the error message but didn't fix the problem. The pre-configured themes don't make any changes I can observe. The User Defined entries only change the navigator buttons on the bottom of the navigator window and not correctly. Using User Defined colors changes only the buttons text , but not the background. I m hoping there is a way to also change the entire navigator window, plus the tool bar and document tabs. There's way too much contrast on the screen for my old eyes.
This issue should now fixed in the new Zeus beta versions found here:
32 Bit: https://www.zeusedit.com/z300/zeus-beta32.zip
64 Bit: https://www.zeusedit.com/z300/zeus-beta64.zip
Jack
Post by Jack »
Thank you Jussi, it now works exactly as expected
