Zeus Lite ships with Zeus SCC-CVS module which allows the IDE to work with the Concurrent Versions System (CVS).
Configuring Zeus SCC-CVS
Start the Zeus IDE and use the Options, Source Control Options menu and select the Zeus SCC-CVS module from the list of installed SCC modules.
Also make sure the Enable SCC Version Control option is selected and use the Advanced SCC Options button to be further customize the features of the plug-in.
Importing a Project into CVS
With the Zeus SCC-CVS enabled it's time to tackle the task of adding something into a CVS archive. Assuming a directory structure that looks something like this:
c:\projects\
+--- cvsroot
c:\work\
+--- example
+--- example.c
+--- example.h
At the DOS command line change to the c:\work\example directory and run the following command line:
cvs.exe -d:local:c:\projects\cvsroot init
The -d:local:c:\projects\cvsroot option tells CVS the location of the CVS archive and this name matches the archive directory that was created earlier.
Another way to tell CVS the location of the archive would be to use the following environment variable:
SET CVSROOT=c:\projects\cvsroot
cvs -d:local:c:\projects\cvsroot import -m "Importing Example" example Vendor Release
The example command line option specifies the name of the imported project.
The Vendor and Release options are two string values that for historical reasons need to be supplied.
If all went well the following output should have been produced:
C:\projects\example>cvs -d:local:c:\projects\cvsroot import -m "Importing Example" example Vendor Release
N example/example.c
N example/example.h
No conflicts created by this import
c:\projects\
+--- cvsroot
+--- CVSROOT
+--- example
+--- example.c,v
+--- example.h,v
With the project successfully imported into the archive, the next step is to use the Zeus SCC-CVS module to interface with this project.
For this to happen a user workspace will be needed so the first step in this process is the creation of the following empty working directory structure:
c:\work\
+--- example
c:\work\example\example.zws
Finally use the Workspace Options menu, select the Source Control panel and type in the following Version Control Configuration details:
Project Name: example
Aux Path: :local:c:\projects\cvsroot
Local Path: c:\work
Check Box: Workspace to use SCC source control interface
This name is vital as it represents the module name as it is know to the CVS archive.
This name must match <I>exactly</I> the name used to import the project into archive. If Zeus SCC-CVS ever has problems opening a CVS project the first thing to check would be the spelling and case of the project name.
The Aux Path defines the location of the CVS archive for this project. Note how this information makes it possible to define the location of the CVS archive on a workspace basis. But it could have just as easily been left blank and the the archive location could have been defined using the following environment variable:
SET HOME=c:\work
Local Path: c:\work\example
If all goes well all the files will now be in the version control system. To test this use the Workspace, Source Control, History menu to display the file history for each of the files listed in the Zeus workspace.
To change a file, it will first need to be checked out, changed and then checked back in to the version control with a suitable comment. If the Zeus SCC-CVS is meant to work more like the real CVS (i.e. without imposing the file-locking paradigm) use the Advanced SCC Options button located in the Zeus Version Control configuration screen.
Using Zeus SCC-CVS with a Remote Archive
As an example of using CVS with a remote archive consider the remote RegExplorer project that is hosted on Source Forge. The web page for this project is:
http://sourceforge.net/projects/regexplorer/
c:\work\
+-- regexplorer
Project Name: regexplorer
Aux Path: :pserver:anonymous@cvs.RegExplorer.sourceforge.net:/cvsroot/regexplorer
Local Path: c:\work\regexplorer
