Use the following wsl.exe command to check a Linux distribution has been installed and is set as active:
wsl.exe --listCode: Select all
Windows Subsystem for Linux Distributions:
Ubuntu-24.04 (Default)
docker-desktop
docker-desktop-dataCode: Select all
wsl -s Ubuntu-24.04Code: Select all
sudo apt updateCode: Select all
sudo apt install build-essential4. Optionally you can install the manual pages for these tools using this command:
sudo apt-get install manpages-devCode: Select all
gcc --versionCode: Select all
gcc (Ubuntu 9.3.0-10ubuntu2) 9.3.0
Copyright (C) 2019 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.Code: Select all
g++ --versionCode: Select all
g++ (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
Copyright (C) 2023 Free Software Foundation, Inc.
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.The Zeus compiler and tool configurations have an option to run the command using Bash. This equates to running the compiler or tool from inside the Linux subsystem.
This means you can run the Linux compilers inside Zeus and have the output captured in the editor.
For example, the image below shows the compiler settings required: The compiler command line used is as follows:
g++ "$f" -g -o "$fb"Testing the Zeus Compiler Setup
Consider a test.cpp that contains the following code:
#include <iostream>
int main(int argc, char *argv[])
std::cout << "Hello World!" << std::endl << std::endl;
for (int i = 0; i < argc; ++i)
std::cout << "Argument: " << i << " => " << argv[i] << std::endl;
return 0;
}Code: Select all
C:\Projects\c++\test.cppCode: Select all
/mnt/c/Projects/c++/test.cppCode: Select all
test test.cppCode: Select all
./testCode: Select all
Hello World!
Argument: 0 => ./test
