Windows 10 Hi-res screen display geometry problems
armarshall
Post by armarshall »
Dell Laptop Inspiron 7548 with resolution at 3840 x 2160 and 250% scaling per manufacturer recommendations.
Zeus 3.98b
A few of the dialogs and tabs are occluded or almost unreadable, particularly the main window
. Is there a later version that resolves these screen display issues ?
I have attached a typical example:
Re: Windows 10 Hi-res screen display geometry problems
Unfortunately I do not have access to any hardware that allows for 250% scaling level :(
Zeus has only every been tested on the 100%, 125% and 150% DPI settings.
The would be no Zeus version of Zeus that has been tested on type of monitor, so they would all fail.
In the next month or so I will see if I can get my hands on one of these 4k monitors.
This issue is fixed in the latest Zeus IDE release found here: https://www.zeusedit.com/download.html
Here's Zeus running on Hi-res screen:
