Additional Keyboard Map Option Needed
avenger
Post by avenger »
Greetings,
I think there should be an additional keyboard map option: Paste Removes Mark.
Currently, when I copy something, double-click to select a word/term and then paste, there is still a selection remaining. This is rather annoying and incongruent with other popular editors. I believe this option should be kept separate from the similar Cut/Copy Removes Mark option.
Thank you for listening. :D
Re: Additional Keyboard Map Option Needed
I am not seeing this behaviour :?
For me all pastes remove the selection mark, so it probably comes down to which function you are using for the paste or how you have configured your new mapping.
Firstly, make sure your new keyboard mapping has the Cut/copy removes mark option set. You will see that option at the top of the Edit Keyboard Mapping dialog.
If that does not fix the issue, you need to determine the function you are using for the paste.
To find out the function use the Macros menu to start a recording, do the paste and stop the recording.
Then use the Macros menu to view the source of the macro just recorded.
Post the name of that function to this thread.
avenger
Post by avenger »
Actually, when copying something, I like to see the selection remain after I copy it. This is congruent with many (most?) other Windows-based text editors, Excel, etc. To me, it is distracting to see my selection suddenly disappear after I press [Ctrl]+[C]. Cutting, though, is another matter entirely. My selection and the cut text should both disappear after a "cut" take place. It puzzles me why cut and copy were ever grouped together and not implemented as separate options.
Cheers :)
The answer to that is hidden in the distant past when Zeus was first developed.
But as Zeus started out life as Brief like clone it might be something that it got from Brief :?
For a long time Zeus only did Brief and the ability to actually change the mappings was only added on the request of other non Brief users.
avenger
Post by avenger »
MarkPasteSmart is the function assigned to [Ctrl]+[V].
You are correct - when Cut/copy removes mark is selected, pasting also removes mark. I did not have this option selected because I like/expect to see my selection after copying until I press some navigation or input key. THanks for the tip. I guess I'll have to endure the remaining selection post-paste because I don't want to give up seeing my selection immediately after a [Ctr]+[C] combination.
Best regards. :)
Naturally you could just put up with these things sort of things that are not to your liking.
But as Zeus is scriptable, another option is to just write a macro and make Zeus do exactly what you want ;)
Here's a macro for the copy behaviour you're looking for:
    if is_window() > 0 then
        if is_marked() > 0 then
            local marked_text = macro_tag("$Marked")
            set_clipboard_text(marked_text )
            message("The marked text has been added to clipboard.")
            message("No text area has been marked!")
        message("To run this macro you need an active window.")
In fact that macro already exist :)
It can be found here:
zScript\copy_to_clipboard.lua
