Documentation structure dbf
afreda
Post by afreda »
Hello,
I would like to know if there is a documenter of the DBF file structure in a directory. In the past I used Dbstrupo but is not compatible with 64-bit operating systems.
GRazie who will respond
Regards
FREDA Hannibal
Re: Documentation structure dbf
I ran a quick Google search for dbf file viewer and it did find a few hints for tools that can handle DBF files.
But not having used any of them I can't tell you if any of them are any good.
The result are here: https://www.google.com.au/?gfe_rd=cr&ei ... ile+viewer
afreda
Post by afreda »
It , is printing the file structure but , unfortunately , for single file
Cheers, Hannibal
