Hi all,
I am new to this forum. I need to add my programming language to zeus. By add, i mean i can run my scripts, i can compile my scripts. My programming language is AutoIt. I have an xml file contains all the keywords of this language. First of all, i need a tutorial on how to setup a new language in zeus. I found a link in main website, but it is only an image of "Document Type" window. So now i am struck, Please help. Thanks in advance
How to add a new language into Zeus
Re: How to add a new language into Zeus
The setup of a new language involves several steps, all centered around the creation of a new document type for language.First of all, i need a tutorial on how to setup a new language in zeus.
Details on how to create and configure a new document type are described here.
You will need to convert that XML file into a simple text file with one keyword on each line. With a file in that format it is easy to import those keywords, as per the details found in the previous link.I have an xml file contains all the keywords of this language.
