I'm using an eval copy of version 3.97y, in Brief emulation mode. It appears that I can only display a single file, in at most two windows - is this true? I was hoping that Zeus would actually behave like Brief, and tile any number of windows and display any specified files in those windows. Is this not possible in Zeus? Also how can I get the F3 key to create either a vertical or horizontal split, according to the specified arrow key? If that is not possible, how can I attach a function key to the horizontal split action?
Thanks.
Multiple window support
Re: Multiple window support
Actually it is one window, but with two views of that one window.It appears that I can only display a single file, in at most two windows - is this true?
No. Zeus does not handle splitting windows as well as the original Brief and is limited to the two views of the one document.
As a once, long time Brief, I do remember how extremely well it could split windows.
You can move the split around (i.e. horizontal to vertical to horizontal etc) but there can only ever be one split at any one time.
The keyboard mappings are configured using the Options, Editor Options menu, using the Keyboard Mapping section and editing the Brief or BriefEx mappings.
One of the difficulties in editing the mapping is determining the name of the function that needs to be bound.
A simple way to figure the function name is to do the following:
- Macro Record Start/Stop menu
- Window Split Vertical menu
- Macro View Source menu
WindowViewSplitVert()
If you find you need more power, you can also create a macro script and bind that to the keyboard instead.
