menu changed
JackR
menu changed
Post by JackR »
I just changed to version 3.97y Beta3. I'm sure you hate feedback like this, but I really miss that you removed the split vert/Hoz entries from the right click menu in the document window. I use it all the time.
Thanks!
Jack
Re: menu changed
Hi Jack,
Those window menu items have been moved to the sub-menu called Arrange and if you look at that sub-menu it is quite long in itself.
That hints as to why the changes were made to the Windows and the File menu. Both those menus where just getting to long!!!!
Why not bind them to one of the F keys, or any other keyboard key for that matter :?:
To find the name of the function to bind do this:
1) Start macro recording
2) Select Window, Arrange menu item
3) Stop macro recording
4) Macros menu, View Source to see the function behind the menu item.
Then just bind that function to any key using the Options, Editor Options menu Keyboard panel.
