scialo
Posts: 6 Joined: Tue Oct 14, 2014 9:42 am
Post
by scialo » Tue Oct 14, 2014 9:59 am
sorry for my english but i don't speak very well.
when i write a code acucobol i start from column 1 and not from column 8.
ES.:
IDENTIFICATION DIVISION.
PROGRAM-ID. TEST.
PROCEDURE DIVISION.
MAIN SECTION.
DISPLAY "HELLO WORLD!".
EX.
STOP RUN.
how can i configure zeus ide for my code?
thanks
Posts: 2650 Joined: Fri Aug 13, 2004 5:10 pm
Post
by jussij » Tue Oct 14, 2014 12:43 pm
The first thing you need to do is edit the COBOL document type.
In that COBOL document type set the left margin cursor to blank.
That will turn off the left comment margin.
Next, in the Keywords section set the line #1 comments details to blank.
That will turn off the line comment at column 7 feature.
scialo
Post
by scialo » Tue Oct 14, 2014 1:59 pm
thanks.
ok i did but when i declare variables starting from column 1 in classes section and variables i see only variables declared on column 7.
es.:
01 f-rec.
03 f-field-01 pic x(20).
03 f-field-02 pic x(100).
03 f-field-03 pic x(15).
03 f-field-04r1 pic 99.99.9999.
03 f-field-04 redefines f-field-04r1.
04 f-field-04-a pic 99 blank when zero.
04 pic x.
04 f-field-04-b pic 99 blank when zero.
04 pic x.
04 f-field-04-c pic 9999 blank when zero.
03 f-field-04r redefines f-field-04r1 pic xxxxxxxxxx.
03 f-field-05 pic zzz.zzz.zz9,99
blank when zero.
03 f-field-05r redefines f-field-05 pic xxxxxxxxxxxxxx.
03 f-field-06 pic x(100).
Post
by jussij » Wed Oct 15, 2014 12:48 am
Ok. You have found a bug in the cobol folder
This issue is fixed in the new
xFolder.dll found here:
To install this new folder, just replace the old
xFolder.dll with the one found in the zip file.
scialo
Post
by scialo » Wed Oct 15, 2014 7:59 am
i did but don't work
scialo
Post
by scialo » Thu Oct 16, 2014 8:25 am
nothing
Post
by jussij » Thu Oct 16, 2014 1:02 pm
nothing
I'm not sure what that means
scialo
Post
by scialo » Thu Oct 16, 2014 1:49 pm
i updated but don't work
Post
by jussij » Fri Oct 17, 2014 1:56 am
Use the
Tags, Rebuild menu to update the tags information.
scialo
Post
by scialo » Fri Oct 17, 2014 9:10 am
thanks, it's ok.
now, can you fix in macros too?
Post
by jussij » Fri Oct 17, 2014 3:15 pm
You need to post some sample source code that highlights the issue.
With that source code, if possible then it will be fixed.
