Mark Text Between Two Fold Points
As the name suggests this macro will mark the text between two fold points. To use the macro place the cursor somewhere between the two folds points and run the macro.
--        Name: Mark Folded Region
--    Language: Lua Macro
-- Description: This macro will mark the region between two fold points. To
--              use the macro place the cursor somewhere in between the fold
--              points and run the macro.
   if (document == 0) then
        message("This macro only works document files.");
        beep();
        return;
    cursor_save()
    if FoldingParentFindPrevious() == 1 then
        local y1 = get_line_pos()
        local x1 = get_cursor_pos()
        cursor_restore()
        if FoldingParentFindNext() == 1 then
            MoveLineEnd()
            local y2 = get_line_pos()
            local x2 = get_cursor_pos()
            -- values taken from Zeuus help file
            local MARK_LINE  = 1
            local MARK_BLOCK = 2
            -- use block mode to mark the region
            set_marked_area(MARK_BLOCK, y1, x1, y2, x2)
            -- uncomment to use line mode to mark the region
            --set_marked_area(MARK_LINE, y1, x1, y2, x2)
        cursor_restore()
    message("No fold points found.")
