Evaluating Agent SVN with PowerBuilder
chamnessd
Post by chamnessd »
I am evaluating Agent SVN for my company. I am using PowerBuilder 9. When I connect to the change control it blocks me from connecting to the database. Is there something I am doing wrong?
It's hard to say but I suspect this is a access control/authentication issue :?
Subversion can be configured for access control and as such, if your access credentials are wrong, it will not let you connect to the repository.
What you need to do is this:
1) Turn on the debug option in the Agent SVN configuration utility
2) Locate the debug log file using the log file button
3) Replicate the issue in the IDE
4) Send me the debug log file to me (e-mail address bottom left)
With that debug information I'll be able to tell you exactly what is going wrong ;)
