Search and Replace
digga333
Search and Replace
Post by digga333 »
I have been using Macromedia Homesite for a long time due to the great search and replace feature.
Just wondering if Zeus has a similar tool?
Having never used Macromedia Homesite it's hard to say.
In terms of the Search and Replace found in Zeus, these are the capabilities of that engine:
  1. Normal and regular expression search and replace
  2. Search for whole words or partial words
  3. Search based on case or case insensity
  4. Search and Replace inside active document
  5. Search and Replace inside all currently open documents
  6. Search all files in the current workspace
  7. Search all files found in a disk folder including sub folders (via fgrep)
  8. Search and Replace via macro scripts and keyboard macros
