I want to eliminate all lines from my file that do NOT start with the string "@ClientToken". I know how to search for ^@ClientToken, and that finds each occurrence of the lines that I want to keep... how do I search for lines that do not start with this string? I've tried encapsulating the string to search for inside parenthesis with a second caret character but that doesn't work.
I Brief, I knew how to code a 2nd buffer and - using Ctrl-N - I could paste the line into the second buffer so that the original remained like it was and the lines I wanted would be in the second buffer... but that doesn't seem to be supported in Zeus.
Thanks!
How to do a NOT pattern search?
This is the regular expression you want:I want to eliminate all lines from my file that do NOT start with the string "@ClientToken".
^(?!@ClientToken)+.*
@ClientToken One Line
Two Line
@ClientToken Three Line
@ClientToken Four Line
Five Line
Two Line
Five Line
You are correct that Zeus does not have a 2nd buffer but since Zeus script can be written in languages like Lua or Python just to name two, it should be fairly easy to simulate this using the scripting language itself.
For example using Python that buffer could be just a list and in Lua it could be a table.
As an example of how to do this using Python, assume this is the text in the current document:
This Zeus Python macro will filter the text of that Zeus document removing all lines that start with the @ClientToken string:
NOTE: The macro above does nothing more than display the results in a message box, but naturally you could have just as easily used Python to write the resulting filtered list to a text file.
For example adding this code just after the last message box will write the filtered list to a file and then load that file into Zeus.
Two Line
Five Line
import re
import zeus
def key_macro():
# must have a document
if zeus.is_document():
all_lines = []
filtered_lines = []
# regexp to filter the lines
exp = re.compile("^(?!@ClientToken)+.*")
# process all lines in current document
for line in range(zeus.get_line_count()):
# note: zeus lines are one based
text = zeus.get_line_text(line + 1)
# add to the all lines list
all_lines.append(text)
# check for a pattern match
if exp.match(text):
# add to the filtered lines list
filtered_lines.append(text)
# join all the lines for the display to follow
lines = '\n'.join(str(n) for n in all_lines)
zeus.message_box(0, lines, "All Lines")
# join the filtered lines for the display to follow
lines = '\n'.join(str(n) for n in filtered_lines)
zeus.message_box(0, lines, "Filtered Lines")
else:
zeus.message("Need a document window!")
zeus.beep()
key_macro() # run the macro
# the name of the file to be created
file_name = "c:\\temp\\output.txt"
# save the filter list to the file
f = open(file_name, 'w')
f.write(lines)
f.close()
# load that file into zeus
zeus.file_open(file_name)
