Problem with Zeus Help system.
kpenner
Post by kpenner »
A co-worker left the company I and inherited his copy of Zeus for Windows (v3.70).
When I try to use the help system I keep getting an error. For example, under
+ Getting Started
+ Menus and Dialog boxes
+ Configuration Dialogs
+ Colors
I clicked on the 'Preset Colors' link and get the following error
Internet Explorer Script Error
An error has occured in the script on this page.
Line: 1
Char: 71
Error: Object doesn't support this property or method
Code: 0
URL: mk:@MSITStore:C:\Program%20Files\Zeus\zeus.chm::/zeusColor_Options_Dialog.htm
Do you want to continue running scripts on this page?
What can I do to fix this?
Can you tell me which version of windows and with what level of service pack are you running?
Zeus uses the Microsoft HtmlHelp for it's online help and for older versions of Windows the HtmlHelp does not work unless some of the later service packs have been applied :(
This might also be a bug with the Zeus help file and as such I have also uploaded the latest Zeus online help to this location: http://www.zeusedit.com/zeushelp.zip
If you download an extract this zip file to the c:\temp location, double clicking on the extracted zeus.chm file should display the latest Zeus help. If this help file works you can just replace the older help file with this latest version.
kpenner
Post by kpenner »
I am using Windows XP Professional version 2002 Service Pack 2
The latest Zeus online help seems to be working fine so I will just use that.
Thanks for the help.
Regards
