Hi
Just a simple question.
Is there a way to keep Zeus editor on top to compare text with other open programs.
While I'm at it. Is there a way to have two instances of Zeus editor open at once.
Thanks.
JLB
Keep on top
No. That feature is not available.
In fact some might say the opposite is true, in that Zeus sometimes forces it's way to the top when it should not
This can be done using the -s command line option and you can see this in action using the Tools, Run Second Instance of Zeus menu.While I'm at it. Is there a way to have two instances of Zeus editor open at once.
For more command line options use the Help, Using and Configuring Zeus menu and in the Index panel search for command line.
