powerbuilder - Add to source control ERROR
rjb80
Post by rjb80 »
i'm not english. i hope your understand
i use your agent_svn .
and Add to source control ERROR
error message
Agent SVN Info:
Agent SVN Info: * Command: svn.exe --non-interactive --trust-server-cert --no-auth-cache --username rjb80 --verbose status dw
Agent SVN Info: * Directory: C:\wizwid\src_new_20140113
Agent SVN : Process started.
Agent SVN : Process running....
Agent SVN Info: 23454 23454 rjb80 dw
Agent SVN : Process completed with exit code: 0
Agent SVN Info: Result: 0 Status Code: 1 (0x1)
Agent SVN Info: * Command: svn.exe --non-interactive --trust-server-cert --no-auth-cache --username rjb80 add d_dw210120lp_01.srd
Agent SVN Info: * Directory: C:\wizwid\src_new_20140113\dw
Agent SVN Info: A d_dw210120lp_01.srd
Agent SVN Info: Result: 0 Status Code: 0 (0x0)
Agent SVN Info: * Command: svn.exe --non-interactive --trust-server-cert --no-auth-cache --username rjb80 commit --no-unlock -m" " d_dw210120lp_01.srd
Agent SVN Info: Adding d_dw210120lp_01.srd
Agent SVN Error: Transmitting file data .svn: E165001: Commit failed (details follow):
Agent SVN Error:
Agent SVN Error: You will need to use a tool like TortoiseSVN to resolve this conflict.
Agent SVN Error:
Agent SVN Error: Alternatively, use the 'Get Latest' option to update the file to the latest version.
Agent SVN Error:
Agent SVN : Process completed with exit code: 1
Agent SVN Info: Result: -19 Status Code: -1 (0xFFFFFFFF)
Agent SVN Info:
Agent SVN Info: =======================================================
Agent SVN Info: Message Box
Agent SVN Info: Transmitting file data .svn: E165001: Commit failed (details follow):
Agent SVN Info: svn: E165001: 커밋 blocked by pre-commit hook (exit code 1) 출력 없음.
Agent SVN Info:
Agent SVN Info: You will need to use a tool like TortoiseSVN to resolve this conflict.
Agent SVN Info:
Agent SVN Info: Alternatively, use the 'Get Latest' option to update the file to the latest version.
Agent SVN Info:
Agent SVN Info: Command: svn.exe --non-interactive --trust-server-cert --no-auth-cache --username rjb80 commit --no-unlock -m" " d_dw210120lp_01.srd
Agent SVN Info: Error Code: SCC_E_FIXMERGE
Agent SVN Info:
Agent SVN Info:
Agent SVN Info:
i want your solution!!!help me..
I will try and help :)
If you look in the log file you will see this error being reported by the SVN client.
From that error output you can see your environment has a pre-commit hook configured and that hook has blocked the commit action.
That error was caused by this SVN command line command:
As you can see Agent SVN was trying to commit the changes to the d_dw210120lp_01.srd file.
You can also see that the user comment for the commit (-m" ") is also blank.
I suspect you have a pre-commit hook configured that does not allow commits without a proper user comment.
Is there an option in PowerBuilder to add a user comment on check in.
If there is then try adding a longer user comment.
