Possible issue with preserving UTF-8 BOM
aphor
Post by aphor »
Both "Editor Options" and "Document Options" contain a section for "File Encoding".
If I set:
- "Editor Options"->"File Encoding"="Automatic" with "Add BOM" checked
- "Document Options"->"File Encoding"="Use editor defaults" ("Add BOM" cannot be selected with this option)
then I expected:
- the default ("Automatic") Editor Option would be to preserve existing file format
However, with those settings, the BOM is stripped from UTF-8 encoded files when saving the modified file and when using "File"->"Save As..." with "Encoding=UTF-8" plus "Add BOM ..." selected, I did not correctly get a BOM on the saved file.
Explicitly setting the "Document Options" to "UTF-8" with "Add BOM" enabled gives me the behavior I want, but I'm not sure if the original configuration was expected to preserve the BOM.
Cheers!
I expected the default ("Automatic") Editor Option would be to preserve existing file format
Yep. That is the way it should work.
And that does look like a bug :(
Watch this space for a new beta version.
I'm having trouble replicating this issue :(
What I did was:
1) Setup the Editor Options as Automatic with Add BOM enabled.
2) Setup the XML Document type as UTF-8 with Add BOM enabled.
3) Setup the Text Document type as automatic.
4) Created a new test1.xml XML file and saved it to disk. Using the HEX dump in the Tools menu I can see that test1.xml file has a BOM.
5) I then did a file Save As of the test1.xml to test1.txt and using the HEX Dump I can see the new test1.txt file also has a BOM.
6) I modify the test1.txt file and do a save of that file that save retains the BOM.
7) I then do a Save As of the test1.txt file to the test2.txt that test2.txt file also retains the BOM.
aphor
Post by aphor »
Thanks for looking.
Following your steps below, I also cannot repro the issue.
If I use "C# Document Type" as the second file type (where you are using "Text Document Type"), though, I see the behavior I originally reported.
I tried going through the full options set for both the text and c# document types, to account for the difference, but didn't come up with a reason it only repros with *.cs files. I can e-mail you my zeuscs-*.ext files if that would help... it may be that I just changed a setting that had an implication I didn't intend.
There did seem to be an issue with the BOM and the file Save As action dialog.
The automatic option does make the BOM behaviour a little more complex and difficult to test.
But I think this issue should be fixed in the latest beta found here: http://www.zeusedit.com/z300/ze397r-beta.zip
aphor
Post by aphor »
That appears to fix it. I'll update this thread if I see any issues, but I'm 5 files in so far and haven't seen anything wrong.
