not sure how to add subdirectories and files in a workspace
by the way is there a user manual
how to add directories and files to workspace
There are at least four ways to create a workspace.
1) You can import Visual Studio solution files and it will create a matching workspace.
2) You can create a workspace by hand.
To do this use the Workspace, New menu to create a new, empty workspace.
Then from inside the Workspace panel right click on different nodes and in the resulting popup menu there are wil be options to add and remove items from the workspace.
3) You can use the Workspace Builder Utility found on the Workspace menu.
That tool will scan folders of the disk for matching files and create a workspace.
4) Finally you can use Windows Explorer to create a workspace.
To do this just create a new workspace with a project then drag and drop files and/or folders onto that project.
There is only the electronic help (F1 key) but that is far from completeby the way is there a user manual
