Detab current document
aphor
Post by aphor »
Replacemnent for CodeWright's Detab() function.
--        Name: Detab
--    Language: Lua Macro
-- Description: Converts all tabs to spaces in the current document.
--              optionally limited to only tabs at the beginning of
--              a line.
    -- macro only works for read / write documents.
    local locked = is_read_only()
        return;
    -- decimal values of user input (see Tools, ASCII Chart menu)
    local YES_KEY_U    = 89  -- Y
    local YES_KEY_L    = 121 -- y
    local NO_KEY_U     = 78  -- N
    local NO_KEY_L     = 110 -- n
    local CANCEL_KEY_U = 99  -- C
    local CANCEL_KEY_L = 67  -- c
    -- ask the user for input
    message("Limit to beginning of line? (Y)es (N)o (C)ancel")
    -- get the user keyboard input response
    local key = keyboard_input()
    if key == YES_KEY_U or key == YES_KEY_L then
        -- find any sequence of tabs at the beginning of a line
        set_find_text("^\t+")
    elseif key == NO_KEY_U or key == NO_KEY_L then
        set_find_text("\t+")
    elseif key == CANCEL_KEY_U or key == CANCEL_KEY_U then
        message("Detab aborted!");
        return;
        message("Invalid response");
        return;
    search_options_save()
    set_search_option("RegExpress", 1)
    cursor_save()
    set_line_pos(1)
    local found = SearchNext()
    if found == 0 then
        message("No tabs found to replace");
        while found == 1 do
            -- create a sequence of spaces equal to the column width of
            -- the tab sequence found to use as the replacement text.
            replace_text = string.rep(' ', get_marked_right() - get_marked_left() )
            set_replace_text(replace_text)
            found = ReplaceNext()
        message("Finished!");
    search_options_restore()
    cursor_restore()
