docstring in python
walto
docstring in python
Post by walto »
Zeus does recognize """ (three double quotes) as start or end of a docstring. Can't seem to get it to recognize ''' (three single quotes) though as a docstring or multiline comment
That is correct. Zeus as present only supports the """ triple (double) quotes and not the ''' triple (single) quotes :(
walto
Post by walto »
jussij wrote:That is correct. Zeus as present only supports the """ triple (double) quotes and not the ''' triple (single) quotes :(
thanks for quick reply Jussi
The double and single triple quotes should now both work in the beta version found here: http://www.zeusedit.com/z300/ze397r-beta.zip
Just make sure the triple quote option is enabled in the Keywords section of the Document Type.
To use the files in this zip file just make a backup copy of the Zeus install folder and replace the files contained in that folder with the ones in the zip file.
walto
Post by walto »
This seems to help.... thanks
jussij wrote:The double and single triple quotes should now both work in the beta version found here: http://www.zeusedit.com/z300/ze397r-beta.zip
