Column number
leonleo
Column number
Post by leonleo »
hi,
Just start using Zeus today!
how can I add column number for my text files.
I'm not sure exactly what functionality you are looking for.
By this do you mean you want a key stroke that adds the current column number to the document :?:
If so you can do that using this Lua macro:
  -- I am not sure it this is the behaviour you are after
  if (is_marked() == 1) then
    message("This macro would delete that marked area.")
  -- save the current cursor
  cursor_save()
  -- write out the current cursor (column) value
  write(string.format("%d", get_cursor_pos()))
  -- restore cursor
  cursor_restore()
You will just need to save this to the cursor.lua file in the zScript folder and then bind that macro to the keyboard.
leonleo
Post by leonleo »
hi,
when i open a text file Zeus displays the only row number but not the column number as Ultra edit does.
Ok, I now understand what you mean and that is the ruler option.
Unfortunately Zeus does not have a ruler option :(
leonleo
Post by leonleo »
its a shame Zeus doesn't have this. If possible could you please add this feature in later versions?
i'm looking for a free notepad editor (similar to ultraedit). I'm using notepad++ and is closest i have. Is there anything else you can recommend?
thanks
When it comes to choices I think there are plenty to choose from. A Google search should help.
As to which of those options is best, I would not know as I only use Zeus ;)
