configuration file
slychiu
configuration file
Post by slychiu »
When we change the options, in which file are these saved?
If i migrate to a new PC I would like to copy the config file across so I do not have to change the options again
It used to be zeus.ini but that does not seem to work anymore
My version is 3.95z
The options are saved in the files contained in the zConfig folder.
On Vista, Windows 7 and Windows the zConfig folder is found here:
C:\Users\CurrentUser\AppData\Roaming\Xidicone\Zeus\zConfig
Note: The folder shown above contains the CurrentUser which represents the user ID of the current user. You need to change that to suit.
You just need to copy over all the files in the zConfig folder to the existing zConfig folder on the new machine. If you have run Zeus once that folder will always exist.
slychiu
Post by slychiu »
Thanks for the quick reply
