both parenthesis highlighted when scrolling
ordba
Post by ordba »
I'm currently on version 3.97e.
I've always used a keyboard mapping with brief as my base line.
I have an old version I still use - 3.93.
I've set the keyboard mapping between the two to be the same.
The problem I'm having with 3.97e is when I use right or left
arrow key over a line that has parenthesis both parenthesis
appear to show a bold cursor - like I'm not in insert mode.
How can I eliminate this visual effect?
Steve
Edit the Document Type and go to the Coloring section, select the Brace Highlighting option and change the colors to suit.
ordba
Post by ordba »
Thanks Jussi - that was the cause.
