Is there a way to get the recent files list to update on open of file, not on close of file?
Or if there isn't, can Zeus update the recent file list when zeus is closed with the files currently open, as it only updates the recent file list when a file is closed
Grant
Recent File question
Unfortunately not.
But when you restart Zeus, the files that where open when it was closed will also be re-opened.Can Zeus update the recent file list when zeus is closed with the files currently open
So why do you need to put those open files on the recent file list as well
What I will do is look to a a macro that lets you put a file onto the recent file list.
That would allow for some level of user configurability
There is a new Zeus beta that will update the MRU on exit if the restore file on startup option is not checked.
The new Zeus beta can be found here: http://www.zeusedit.com/z300/ze397q-beta.zip
