xtags.exe in z300 fails
Error message "can't start because rxspencer.dll is missing"
I suspect you have not run the full installer.
The files found here are just patch files and can not be used without first installing the software:
http://news.ycombinator.com/newest
You need run the full installer found here: http://www.zeusedit.com/z300/ze32v397p.zip
But you will also need to delete this folder before running the installer:
NOTE: <CurrentUser> above is you current user ID.
C:\Users\<CurrentUser>\AppData\Roaming\Xidicone\Zeus
